Croduino SMD fuse burned out when connecting to +5V
I damaged a Croduino and would like to repair it with your help. When connecting to +5V, one component smoked and was probably destroyed. It’s an SMD part marked “bm” on a green background, the first one next to the USB connector. I could replace it if you could tell me what it is and what else I need to find such a part.
Uspio sam pokvariti jedan Croduino pa bi ga uz vašu pomoć možda mogao popraviti.
Prilikom spajanja na +5 V jedna se komponenta zadimila
i vjerojatno uništila. To je SMD dio sa oznakom bm na zelenoj pozadinim prvi uz USB utičnicu.
To bi mogao zamjeniti ako mi možete reći što je to i
ostalo potrebno da nađem takav dio.
Hvala unapred na odgovoru.
[name removed].
Originally submitted via email support on 10 January 2019. Migrated to the forum for community visibility.
After many difficult attempts to register, I got this error: “Can’t connect securely to this page. This might be because the site uses outdated or unsafe TLS security settings. If this keeps happening, try contacting the website’s owner.” Could you please forward my question from today to your technical team or the Forum.
Nakon mnogih mučnih pokušaja registriranja dobio sam ovo:
Molim vas da umjesto mene proslijedite moje pitanje koje sam vam danas postavio, vašoj tehničkoj službi
ili Forumu.
Hvala
The component that burned out is a fuse - its purpose is to protect the rest of the board if something goes wrong. You can find the same type of fuse at https://e-radionica.com/hr/resetabilni-smd-osigurac-0-5a-1206.html and replace it on your board. If it burns out again, something else on the board or something connected to the board is not functioning as expected, so the error is elsewhere. But the first step is definitely to replace the fuse.
čini se da browser želi HTTPS :slight_smile: nema frke, u pravu je, mi ćemo ispraviti grešku, a Vaš odgovor slijedi:
dio koji Vam se zadimio je osigurač i njegova je svrha upravo to - da zaštiti ostatak pločice ako se dogodi nešto što se ne bi trebalo dogoditi. Isti takav osigurač možete pronaći ovdje: https://e-radionica.com/hr/resetabilni-smd-osigurac-0-5a-1206.html
i zamijeniti na svojoj pločici. Ako Vam opet izgori, nešto drugo na pločici ili nešto što je spojeno na pločicu, ne funkcionira kako je očekivano pa treba tražiti na drugom mjestu grešku. Ali definitivno prvi korak je zamijeniti osigurač.
