Croduino STM32 pin layout and USB code upload
I need a detailed pin layout for the Croduino STM32 (STM32F103C8T6), specifically which pins have RX and TX. Is it also possible to upload code to it via micro USB only?
trebao bih ako imate pin layout detaljni za umirovljeni croduino stm32 ( STM32F103C8T6) točnije na kojim pinovima se nalaze rx i tx. Također jel moguće samo preko micro usb-a uploadati kod na njega.
Hvala,
Originally submitted via email support on 19 January 2024. Migrated to the forum for community visibility.
The schematic for the breakout is attached. For code upload, the Arduino STM32 board definition was installed on this board, which includes code loading over UART. You can try using that: GitHub - stm32duino/Arduino_Core_STM32: STM32 core support for Arduino · GitHub
šaljem shemu za taj breakout priloženo, nadam se da će pomoći.
Za upload koda, ako se dobro sjećam, ja sam na tu pločicu stavio Arduino STM32 board definition što sadržava učitavanje koda preko UARTa, pa možeš probati s time. GitHub - stm32duino/Arduino_Core_STM32: STM32 core support for Arduino · GitHub
Attachment omitted in migration: STM32F103_breakout.pdf
