Croduino: storing serial data on PC and using Serial Monitor input
After transferring data from Croduino to PC using serial.print(), I want to do something with that data (calculations, graphical display, etc.). How can I access it independently from Croduino and store it somewhere for further use?
The data appears in a window with COM4 in the title. Below that, something can be typed and a “send” button clicked. What does this mean, what should be typed, and where does it go?
Nakon što prenesem podatke iz Croduina na PC ( serial.print() )
htio bi s tim podacima nešto raditi, (računati, grafički prikaz, i t.d.).
kako doći do njih neovisno o Croduinu. kako ih negdje spremiti za dalju upotrebu?
Podaci se prikazuju u prozoru koji ima kod mene u naslovu COM4,
ispod toga se može nešto upisati i kliknuti na “send”,
što to znači, što treba upisati i kuda se to šalje, ako se šalje?
[name removed].
Originally submitted via email support on 3 January 2016. Migrated to the forum for community visibility.
To manipulate the data, you need to write a small script on your computer that will read that data. Do you use any particular programming language? We have a small tutorial for Python here: https://e-radionica.com/hr/blog/2015/09/22/croduino-i-python/
Send is the same as pressing Enter. It sends the string you type in the Serial Monitor input line, and you can read it in your Arduino sketch using a special library and execute commands based on it. For example, in your sketch you can set it so that if it receives “off” from the Serial Monitor, it turns off an LED and similar things.
kako biste manipulirali podacima morate napraviti malu skriptu na računalu koja će čitati te podatke. Služite li se nekim posebnim programskim jezikom? Ovdje imamo mali tutorial za Python : https://e-radionica.com/hr/blog/2015/09/22/croduino-i-python/
Send je isto što i Enter tipka. Šalje string koji upišete u traku Serial Monitoru, a možete ju čitati pomoću posebnog librarya u skripti Arduino IDEa te izvoditi naredbe pomoću nje. Npr. u skiptu upisete ako dobije “off” s Serial monitora da ugasi LED diodu i slično.
