Croduino temperature sensor projects with WiFi and Ethernet
I need advice on two possible approaches for a temperature sensor project. We’re considering both WiFi and Ethernet options.
For the WiFi option, we’re already using Croduino NOVA with a waterproof DS18B20. Could you recommend a suitable power supply and confirm the required 4.7k pullup resistor?
The second option would be a board with an Ethernet connector and power that could be delivered as PoE. We’d use the same sensor.
Initially we’d purchase 10 complete sets (5 WiFi and 5 Ethernet) for testing with our users.
Nastavno na današnji razgovor molio bih Vas prijedlog rješenja vezanih uz mogući projekt temperaturnih senzora.
Interesiraju nas dvije opcije (WiFi i Ethernet).
Za Wifi opciju već koristimo : Croduino NOVA + vodootporni DS18B20 i tu bih Vas još molio prijedlog napajanja i potrebni otpornik (4.7k)
Druga bi opcija bila pločica sa Ethernet priključkom i napajanjem koje bi se moglo izvesti kao PoE. Senzor bi bio isti.
Za početak bi kupili 10 kompleta (5wifi i 5 Ethernet) koje bi dali našim korisnicima na testiranje.
Puno hvala na povratnim informacijama.
Originally submitted via email support on 23 August 2017. Migrated to the forum for community visibility.
For NOVA power supply: A 5V power supply can be connected directly to the 5V pin, but the recommendation is to use a 3.3V power supply to avoid using the on-board regulator, which reduces heat generation and improves efficiency.
For Ethernet with PoE and microcontroller, we have solutions using Croduino NET with a PoE module. However, these are not currently in stock and would need to be produced again and customized for your design.
If PoE is not essential, you can use:
  • Croduino Basic2 (microcontroller, Arduino-compatible)
  • Ethernet module: either Arduino Ethernet Shield with W5100 (simpler, especially if you only need one connection) or ENC28J60 Ethernet module
Regarding PoE, unfortunately there are very few readily available options. PoE is not commonly used in hobby or semi-industrial projects. We’re looking into other suppliers but availability is limited. We can discuss what you’d like to order and explore customization options.
hvala na svim detaljima - drago mi je da smo se čuli. Mi, osim asortimana kojega vidite na našem webu, se bavimo razvojem i dizajnom elektroničkih proizvoda pa smo uvijek dostupni za sva pitanja i suradnju.
Napajanje za NOVU: ovo je dobro napajanje ako imate kučište za njega, može se spojiti direktno na 5V pin: Jedinične napajanja | Pouzdani izvori napajanja – Soldered Electronics
ili klasično USB: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
​​​​Inače za Ethernet + PoE + mikrokontroler mi imamo rješenje kao na slici(Croduino NET, bez zalemljenog PoE modula.. jedina slika koju imam pri ruci):
Dropbox - Error - Simplify your life
nažalost nemam niti jedan više pri ruci. Kažem možemo ih praviti opet, možemo ih prilagoditi Vašem dizajnu, ali kad budemo imali neke količine.
Sad ne znam koliko je PoE obavezan.. ako Vam PoE ne treba, možete ići s:
Croduino Basic2(mikrokontroler, zapravo Arduino) Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
te Ethernet modul:
https://e-radionica.com/hr/arduino-ethernet-shield-s-w5100.html
ili
https://e-radionica.com/hr/enc28j60-ethernet-modul.html
(W5100 je jednostavniji, posebno ako trebate samo napraviti jednu konekciju)
za PoE nažalost nemam baš ništa pri ruci. Gledam i neke druge dobavljače, nitko nema. Nije baš uobičajno koristiti PoE u hobby/semi-industrial projektima, pa valjda zbog toga ih ni nema puno. Jedina opcija koju vidim je Kina u ovom trenu, ali to nikako nije brzo. Sad sam malo u gužvi, budem posljepodne još malo pretražio.
Javite se na mobitel svakako nakon što vidite email da vidimo što biste naručili, loši smo sa stanjem NOVE, u zadnjih 2 tjedna prodali smo 50 komada.
Čujemo se;
Ako budete trebali pomoć s napajanjem baterijama, javite se - specijalizirani smo za Li-ion baterije.
Could you send me that “trick” regarding IP address and SSID configuration for Croduino?
Samo bih Vas podsjetio da mi pošaljete onaj „trik“ vezano uz konfiguraciju IP adresa i SSID kod konfiguracije Croduina.
Hvala i LP
Sekom d.o.o.
Palinovecka 27
Zagreb
Croatia
( T: [phone removed] F: [phone removed]
) M:
:W: www.sekom.hr (http://www.sekom.hr/)
  • E: [email removed]
Regarding IP address and SSID configuration: the solution is called WiFiManager. It works by having the ESP8266 create an AP that you can connect to with a laptop or mobile device. Once connected, you can enter the desired configuration information (such as IP address), select and connect to a WiFi network, etc. In your case, you would do this on-site for each location specifically.
More information: GitHub - tzapu/WiFiManager: ESP8266 WiFi Connection manager with web captive portal · GitHub
Složit ćemo nekakvo kučište :slight_smile:
Što se tiče IP adresa/SSID, stvar se zove WiFiManager i radi tako da prvo ESP8266 napravi AP na kojega se spojite s laptopom/mobitelom na kojemu se mogu unjeti željene info(npr. IP adresa), odabrati i spojiti na WiFi mrežu i drugo. U Vašem primjeru to onda odradite na licu mjesta, za svako mjesto specifično.
više info ovdje: GitHub - tzapu/WiFiManager: ESP8266 WiFi Connection manager with web captive portal · GitHub
