I need a voltage sensor for Croduino that can measure 0-/+5V or at least 0-5V and 0-36V with galvanic isolation. I cannot find one on your website.
Poštovani, trebao bi mi za croduino senzor za mjernje napona 0-/+5V ili makar od 0-5V te 0-36V uz galvansko odvajanje na Vašim internetskim stranicama ne mogu pronaći.
Hvala. [name removed]
Originally submitted via email support on 13 July 2017. Migrated to the forum for community visibility.
What precision do you need for the sensor? What tolerance is acceptable?
koliku preciznost trebate za navedeni senzor?(koliko je dopušteno odstupanje?)
I need standard precision, nothing special. I’ll be measuring voltage from 1.2V with expected peaks above 5V. I’m only in the development phase. A deviation of 0.1–0.2V is acceptable to me.
treba mi standardna preciznost ništa specijalno, mjeriti će se napon od 1,2V s očekivanim pikovima preko 5 V.
Tek sam u razvojnoj fazi. Odstupanje od 0,1 – 0,2V mi ne igra ulogu.
LP [name removed].
