When connecting a Croduino and Ethernet Shield, is it correct to power both boards from a USB port (from a PC), which I’m also using for communication? I’m not sure if that’s safe - I don’t want to overload the Croduino’s power supply. If that’s not recommended, I would power the Ethernet Shield from an external 5VDC supply and the Croduino from USB.
Samo bih vas molio za još jednu informaciju:
Kada se spoje Croduino i ethernet shield da li je korektno da se obje pločice napajaju s USB priključka (iz PCa), a koja mi ujedno služi i za vizualizaciju.
Nisam siguran da li je to u redu – kako ne bi previše opteretio napajanje Croduina.
U slučaju da se to ne preporuča, onda bi Ethernet shield napajao iz vanjskog 5VDC napajanja, a Croduino iz USBa.
Hvala vam na pomoći. LP,
Originally submitted via the contact form on soldered.com on 2 January 2018. Migrated to the forum for community visibility.
