Damba upload fails with signature 0x000000 or 0xffffff
I successfully uploaded a program this morning and haven’t changed the configuration since. I suspected one digital output wasn’t working so I wanted to test it, but now nothing works at all. Could the error message in the attachment mean the Damba is broken?
[name removed] bok!
Je li poruka iz priloga može značiti da mi je Damba riknula?
Jutros sam zadnji put uspješno uploadao program i u međuvremenu nisam mijenjao konfiguraciju. Sumnjao sam da mi jedan dig.. izlaz ne radi pa sam to htio provjeriti, ali ispada da uopće ne radi.
Originally submitted via email support on 7 May 2018. Migrated to the forum for community visibility.
Enable “verbose” mode in the upload settings. That will print more information. If you see signature 0x000000, it could mean the board isn’t properly connected. If you see 0xffffff, it could mean the controller is burned out.
Did you accidentally use the rst pin as a digital pin?
oprosti na zakašnjelim odgovorima.. bili praznici pa smo išli na sajam u Beč.. sinoć stigli i sada imam ogroman backlog emailova :slight_smile:
Daj molim te u postavkama uključi “verbose” prilikom uploada. Onda bi se trebalo ispisati nešto više informacija. Ako ti je signature 0x000000 to bi moglo značiti da pločica nije dobro povezana. Ako je 0xffffff - to bi moglo značiti da je kontroler spržen.
Jesi li možda slučajno koristio rst pin kao digitalni pin?
