I received two Dambos with pre-installed batteries that were completely discharged. I assume this happened because they were already installed before shipping. I recommend adding a note to the Dambo product description that batteries are available for purchase separately.
I also couldn’t program the Dambo until I powered it with 5V as mentioned in the comments. Either fix the downloadable code or update the fritzing diagram.
Kupio sam dva Damba koji su došli s ugrađenom baterijom koja je bila ispražnjena. Pretpostavljam zato jer je bila ugrađena. Preporučam da u opisu Damba upiše da imate i baterije za kupiti.
Također nisam mogao programirati Damba ako nisam ga napojio s 5V kako piše u komentarima. Ili ispravite kod za download ili promijenite fritz.
Originally submitted via email support on 20 March 2018. Migrated to the forum for community visibility.
