How do I set up Dasduino CONNECT to work in the Arduino IDE? Which board should I select? Do I need to install the board definition from GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub or can I use it without it? Are there any setup instructions available online?
da bi dasduino connect funkcionirao unutar Arduino IDE sucelja sto je potrebno, koji board odabrati?
Da li je potrebno instalirati board definition (GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub) ili moze bez njega?
Ako postoje neke upute na internetu moze link na upute.
Originally submitted via email support on 2 March 2023. Migrated to the forum for community visibility.
You can use the board definition from that link. You can also use the ESP8266 board definition since Dasduino contains that same chip - in that case you need to select the correct ESP8266 variant, as there are several. Installing our board definition follows the same process as in the video: paste our link and search for Dasduino. You cannot use it without a board definition - you must have at least one board definition for ESP8266 microcontrollers to upload code to it. Almost all tutorials and guides you find online for ESP8266 (NodeMCU, Wemos, etc.) apply to our Dasduino as well, since it runs the same chip.
Možete koristiti naš board definition sa linka, a također možete koristiti za ESP8266 jer se na Dasduinu nalazi taj isti čip (samo je u tom slučaju potrebno odabrati točno tu inačicu ESPa jer ih ima više). Instalacija našeg board definitiona je na isti način kao i u videu, samo zaljepite naš link i tražite Dasduino. Ne možete bez njega, morate imati barem jedan board definition za ESP8266 mikrokontrolere kako bi moglu uploadati kod na njega. Gotovo sve upute i tutorijali na internetu koje možete pronaći za ESP8266 (NodeMCU, Wemos, …) vrijede i za naš Dasduino jer ih pogoni isti čip.
