I’ve made some progress on my project. Now Arduino IDE is giving me this error message:
Executable segment sizes:
ICAM : 32768 – flash instruction cache
IROM : 253012 – code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28273 / 32768 – code in IRAM (IRAM_ATTR, ISRs…)
DATA : 1508 ) – initialized variables (global, static) in RAM/HEAP
RODATA : 2500 ) / 81920 – constants (global, static) in RAM/HEAP
BSS : 26776 ) – zeroed variables (global, static) in RAM/HEAP
Sketch uses 285293 bytes (29%) of program storage space. Maximum is 958448 bytes.
Global variables use 30784 bytes (37%) of dynamic memory, leaving 51136 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM3
Connecting……..…..…..…..…..…..….._____
File “C:\Users[user]\AppData\Local\Arduino15\packages\Dasduino_Boards\hardware\esp8266\1.0.0/tools/upload.py”, line 66, in
esptool.main(cmdline)
File “C:/Users/UENIK/AppData/Local/Arduino15/packages\Dasduino_Boards\hardware\esp8266\1.0.0/tools/esptool\esptool.py”, line 3552, in main
esp.connect(args.before, args.connect_attempts)
File “C:/Users/UENIK/AppData/Local/Arduino15/packages\Dasduino_Boards\hardware\esp8266\1.0.0/tools/esptool\esptool.py”, line 529, in connect
raise FatalError(‘Failed to connect to %s: %s’ % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
My program:
#define BLYNK_PRINT Serial
#define BLYNK_TEMPLATE_ID "TeoZavrsni"
#define BLYNK_TEMPLATE_NAME "MeteoPostaja"
#include <BlynkSimpleEsp8266.h>
#include <BlynkTimer.h>
#include "DHTesp.h"
#ifdef ESP32
#pragma message(THIS EXAMPLE IS FOR ESP8266 ONLY!)
#error Select ESP8266 board.
#endif
int Sensor_PIN = 4; //D3
DHTesp dht;
char auth[] = "";
char ssid[] = "";
char pass[] = "";
float Temperature;
float Humidity;
BlynkTimer timer;
void myTimerEvent()
Temperature = dht.getTemperature();
Humidity = dht.getHumidity();
Blynk.virtualWrite(V5, Temperature);
Blynk.virtualWrite(V6, Humidity);
void setup()
Serial.begin(9600);
dht.setup(Sensor_PIN, DHTesp::DHT11);
Blynk.begin(auth, ssid, pass);
timer.setInterval(1000L, myTimerEvent);
void loop()
Blynk.run();
timer.run();
Poštovani došlo je do nekog malog progresa u mom projektu s obzirom na prošlo pitanje sada od Arduino IDE dobivam sljedeću poruku o grešci:
ICACHE : 32768 – flash instruction cache
esptool.py v3.0
Serial port COM3
File “C:/Users/U�ENIK/AppData/Local/Arduino15/packages/Dasduino_Boards/hardware/esp8266/1.0.0/tools/esptool\esptool.py”, line 3552, in main
File “C:/Users/U�ENIK/AppData/Local/Arduino15/packages/Dasduino_Boards/hardware/esp8266/1.0.0/tools/esptool\esptool.py”, line 529, in connect
Moj program sad izgleda ovako:
#define BLYNK_TEMPLATE_ID “TeoZavrsni”
#define BLYNK_TEMPLATE_NAME “MeteoPostaja”
#include
#include
#include “DHTesp.h”
#ifdef ESP32
#endif
DHTesp dht;
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth = “”;
// Your WiFi credentials.
// Set password to “” for open networks.
char ssid = “”;
char pass = “”;
float Temperature;
float Humidity;
BlynkTimer timer;
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void myTimerEvent()
Temperature = dht.getTemperature(); // Gets the values of the temperature
Humidity = dht.getHumidity(); // Gets the values of the humidity
// You can send any value at any time.
// Please don’t send more that 10 values per second.
void setup()
// Debug console
Serial.begin(9600);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
// Setup a function to be called every second
void loop()
Blynk.run();
timer.run(); // Initiates BlynkTimer
Molim za pomoć
Originally submitted via email support on 30 April 2024. Migrated to the forum for community visibility.
