I cannot find the Dasduino Connect board in Arduino IDE. Can you help me with this?
Pozdrav, u ARDUINO IDE nemogu pronaći vašu pločicu Dasduino connect. Mislio sam da Vi znate više o tome.
Originally submitted via email support on 25 September 2024. Migrated to the forum for community visibility.
To get started with the Dasduino Connect, you first need to install the board. The installation instructions are in the README at the bottom of the GitHub repository: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub
After installation, you’ll be able to select the Dasduino Connect board and use it to upload code.
kako bi započeo sa radom na Dasduino Connect, potrebno je prvo instalirati Pločicu, evo linka GitHub repozitorija gdje možeš naći upute kao to napraviti untar README-ja (na dnu stranice): GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub
Onda ćeš moći instalirati Dasduino Connect pločicu i koristiti ju za upload koda.
Javi ako negdje zapne ili imaš još pitanja vezana uz naše proizvode.
