Dasduino Connect Plus Bluetooth not detected by phone or Serial Terminal app
I work in a school and we received six kits with Dasduino Connect Plus boards as part of a project. I’ve been learning to use them and have successfully connected many components that work well.
However, I’ve tried to connect the Dasduino to Bluetooth following many available video tutorials, using the Bluetooth Serial Terminal app, and I haven’t been able to get it to work. The phone simply doesn’t recognize the Dasduino board (ESP32) as a Bluetooth transmitter no matter what I try.
Is there some detail that needs to be done or known in order to make this work?
Radim u školi i dobili smo u sklopu projekta Generacija NOW šest kutija setova opreme sa Dasduino Conect plus pločicama. Učim ih se koristiti i dosta elemenata uspješno spajao i dobro je funkcioniralo.
No pokušavao sam prema mnogim dostupnim video lekcijama povezati Dasduino sa bluetooth signalom, aplikacijom Bluetooth Serial Terminal i to nikako nisam uspjevao. Naprosto korištenjem dostupnih primjera za BT signal mobitel nikako ne prepoznaje Dasduino pločicu (ESP32) kao odašiljača BT signala.
Ima li tu neki detalj koji treba učiniti, znati a da to funkcionira ?
Originally submitted via email support on 27 January 2023. Migrated to the forum for community visibility.
Try pairing the Dasduino with your phone in the phone’s settings first, then use the Serial Bluetooth Terminal app.
The issue could also be with the phone itself. I previously had a Xiaomi phone and after a software update I couldn’t connect to any microcontroller via Bluetooth. You can try with a different phone.
If none of that works, send me the code you’re using and we can see where the problem is.
Pokušajte se prvo upariti sa Dasduinom u postavkama telefona, a tek onda u Serial Bluetooth Terminal aplikaciji.
Može biti i do telefona, imao sam prije Xiaomi telefon i poslje jedne nadogradnje nisam se mogao više povezati na niti jedan mikrokontroler preko Bluetootha. Možete pokušati sa drugim telefonom.
Ukoliko Vam nebude radilo ništa od navedenog, pošaljite mi kod koji ste koristili pa ćemo vidjeti gdje je problem.
I tried following your advice to pair the phone with the Dasduino first, and also tried with a different phone, but I still couldn’t find the Bluetooth signal from the Dasduino. Here’s the code I’m using, which is from the examples that came with the BluetoothSerial library:
//This example code is in the Public Domain (or CC0 licensed, at your option.)
//By Evandro Copercini - 2018
//This example creates a bridge between Serial and Classical Bluetooth (SPP)
//and also demonstrate that SerialBT have the same functionalities of a normal Serial
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
void setup() {
  Serial.begin(115200);
  SerialBT.begin("ESP32test"); //Bluetooth device name
  Serial.println("The device started, now you can pair it with bluetooth!");
void loop() {
  if (Serial.available()) {
    SerialBT.write(Serial.read());
  if (SerialBT.available()) {
    Serial.write(SerialBT.read());
  delay(20);
The code uploads fine to Arduino IDE 2.03 and prints text to the Serial Monitor. In the video tutorials they always mention pressing a button on the ESP32 board after uploading. I tried pressing both the RESET button and another button, but nothing happened.
Pozdrav [name removed] i zahvaljujem na odgovoru. Pokušao sam prema savjetima upariti prvo telefon i Dasduino, pokušao sam i sa drugim mobitelom no nisam sam uspio pronaći BT signal od Dasduina. Evo šaljem i program koji koristim koji se inače nalazi u primjerima koji su stigli sa BluetoothSerial knjižnicom:
//This example code is in the Public Domain (or CC0 licensed, at your option.) //By Evandro Copercini - 2018 // //This example creates a bridge between Serial and Classical Bluetooth (SPP) //and also demonstrate that SerialBT have the same functionalities of a normal Serial
#include “BluetoothSerial.h”
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED) #error Bluetooth is not enabled! Please run make menuconfig to and enable it #endif
void setup() { Serial.begin(115200); SerialBT.begin(“ESP32test”); //Bluetooth device name Serial.println(“The device started, now you can pair it with bluetooth!”); }
void loop() { if (Serial.available()) { SerialBT.write(Serial.read()); } if (SerialBT.available()) { Serial.write(SerialBT.read()); } delay(20); }
Inače program mi se uredno uplouda na Arduino IDE 2.03 i ispisuje neki tekst na Serial Monitoru. Na video lekcijama - uputama uvijek se navodi da se nakon uplouda programa pritisne tipka na ESP32 pločici. Ja sam probao pritisnuti i tipku RESET i tipku RESET međutim nema rezultata.
I made an error in the previous message. I tried pressing both the RESET button and the USER button. Sorry about that.
Pogrešno napisao u prethodnoj poruci. Probao sam pritisnuti tipku RESET i tipku USER. Isprika.
Try changing the board in Arduino IDE to “ESP32 Wroover”. It might be an error in our board definition.
If you don’t have the ESP32 boards installed, there’s a short tutorial here.
Let us know if that works so we can fix the error in our board definition.
Pokušajte promijeniti pločicu u Arduino IDE na “ESP32 Wroover”, možda je pogreška u našem board definitionu.
Ako nemate instalirane ESP32 pločice, ovdje je kratak tutorijal.
Javite nam se svakako jeste li uspjeli tako da znamo popraviti grešku u našem board definitionu.
It’s working now. After I installed and selected the ESP32 Wrover Module board in Arduino IDE, the phone and the Serial Bluetooth Terminal app now recognize the Dasduino (ESP32) and I can send messages to the Serial Monitor from the phone.
I’m planning to use this in some school projects where I previously used the Blynk app with Wi-Fi. Now I want to try controlling servo motors via Bluetooth instead. I’ve 3D printed robot arms where I used Blynk sliders or joysticks, and I’ll see if I can make them work with a Bluetooth app instead.
One last question: for other projects where I don’t use Bluetooth, should I select the Dasduino Connect Plus board or the ESP32 Wrover board in Arduino IDE?
Thank you again.
E sad radi. Nakon što sam instalirao i postavio pločicu ESP32 Wrover Modul u Arduino IDE, mobitel i aplikacija Serial Bluetooth Terminal prepoznaju Dasduino odnosno ESP32 i mogu slati poruke na Serial monitor sa mobitela. Hvala na savjetima. Inače planiram u nekim školskim projektićima gdje sam prije koristio Blynk aplikaciju i Wi-Fi pokušat sada upravljati servo motorima pomoću BT signala. Pošto je riječ o nekim robo rukama 3D printanim, gdje sam koristio klizne slidere ili joysticke u Blynku, vidjet ću još dali ću to i uspjeti i pomoću bluetooth aplikacije.
Još me na kraju zanima dali da u drugim projektima gdje ne koristim BT signal u Arduino IDE spajam pločicu Dasduino Conect Plus ili ESP32 Wrower ?
Još jednom hvala i srdačan pozdrav.
I’m glad you managed to solve it.
Everything should work with the Dasduino Connect Plus board in Arduino, but it looks like there’s a bug that we’ll try to fix soon. Actually there shouldn’t be much difference between the boards in Arduino since the Dasduino contains an ESP module and we just added some extras to make it easier to use. We don’t know of any other bugs at the moment, so everything else should work with the Dasduino board, but if it doesn’t work, you can always try it this way.
Drago mi je da ste uspijeli riješiti.
Inače bi sve trebalo raditi sa Dasduino Connect Plus pločicom u arduinu, ali izgleda da postoji bug pa ćemo nastojati riješiti ga što prije. Zapravo i nebi trebalo biti prevelike razlike u pločicama u arduinu jer se na Dasduinu nalazi ESP modul, samo smo mi dodali još neke sitnice da bi olakšali korištenje. Za sada nam nisu poznati neki drugi bugovi pa bi za sve ostalo trebalo raditi sa Dasduino pločicom, ali ako ne radi, možete uvijek ovako pokušati.
