Dasduino Connect Plus PlatformIO support and ESP32 WROVER board selection
Dasduino Connect Plus works fine with custom library. Does it support development in PlatformIO VSCode for development and which model should I select from the list? How do I load a clean WROVER model?
Dasduino Connect Plus radu uredno sa custom lib.
Podržava li razvoj na PlatformIO VSC za razvoj i koji model odabrati sa liste. Kako učitati čistom model Wroove-e?
Attachment omitted in migration: signature_ALS-Logo-Main.png
Attachment omitted in migration: signature_0aeea524.png
Originally submitted via email support on 12 April 2024. Migrated to the forum for community visibility.
We personally use VSCode + Arduino extension which works great. From personal experience, I can tell you that Dasduino CONNECTPLUS supports upload with board definition for generic ESP32 WROVER, which is otherwise called “ESP32 Dev Module” in Arduino. The only thing you won’t have is onboard WSLED but you can always add that through software. Through brief research, I believe that platform should be called ‘ESP-WROVER-KIT’.
I believe it’s from this repository: GitHub - platformio/platform-espressif32: Espressif 32: development platform for PlatformIO · GitHub
mi osobno korisimo VSCode + Arduino ekstenziju što radi super. Ali iz osobnog iskustva mogu Vam reći da Dasduino CONNECTPLUS podržava upload sa board definicijom za generic ESP32 WROVER-e, mislim da je to inače nazvano “ESP32 Dev Module” u Arduinu. Jedino što nećete imati je onboard WSLED ali to možete uvijek dodati kroz softver. Kroz kratko istraživanje, mislim da bi se taj platform trebao zvati ‘ESP-WROVER-KIT’
I vjerujem da je to s ovog repozitorija: GitHub - platformio/platform-espressif32: Espressif 32: development platform for PlatformIO · GitHub
Nadam se da je ovo bilo informativno.
