Dasduino Connect Plus with Arduino Cloud connection issues
Can the Dasduino Connect Plus be connected to Arduino Cloud? I tried adding it as an ESP32 device, selecting options like “ESP32 Wrover Kit (all versions)”, “ESP32 Wrover Module”, and “ESPea32”. The device was recognized successfully and an ID and Secret key were generated, but when I entered the network connection data, the device remained offline.
Poštovani, može li se Dasduino Connectplus (https://soldered.com/product/dasduino-connectplus/) povezati s arduino cloudom (https://login.arduino.cc).
Pokušao sam dodati ESP32 uređaj i to kao “ESP32 Wrover Kit(all versions)”, “ESP32 Wrover Module” i “ESPea32”.
Dobijem poruku da je uspješno prepoznat te se generira Id i Secret key ali kada unesem podatke za spajanje na mrežu uređaj je uvijek offline.
Originally submitted via email support on 1 March 2023. Migrated to the forum for community visibility.
This should work because it is essentially an ESP32 module.
To bi trebalo raditi jer to nije ništa drugo nego ESP32 modul.
Možete pokušati slijediti ove upute.
The Freenove ESP32 WROVER board is supported, and it has the same ESP32 WROVER module as the Dasduino Connect Plus, so there should be no problem with that. Generally, most things that work with other ESP32 boards (NodeMCU, Wemos, etc.) should work with Dasduino Connect Plus, except for specific features that require a particular ESP module that isn’t the ESP32 WROVER module.
Prema ovome, podržana je pločica Freenove ESP32 WROVER, a ona na sebi ima ESP32 WROVER modul kao i Dasduino Connect Plus tako da smatram da s time nebi trebalo biti problema.
Inače ne radimo support za takve stvari pa Vam ne mogu detaljnije reći kada nažalost nismo isprobali sve to. Uglavnom, sve što vrijedi za ESP32 pločice (NodeMCU, Wemos, …), većina bi trebala raditi na Dasduino Connect Plus, osim nekih specifičnih stvari za koje treba određeni ESP modul koji nije ESP32 WROVER modul.
