Dasduino CONNECT technical documentation and solar charging setup
Where can I find the technical specification for the Dasduino CONNECT module? Is there documentation available to download?
Napravio sam novu narudjbu: 31928 … medjutim nema mi puno smisla realizirati narudzbu ako ne mogu doci do tehnicke specifikacije DASDUINO Connect modula. Gdje mogu pogledati tehnicke podatke za isti?
Postoji li neka dokumentacija o Dasduino CONNECT koju mogu od nekuda skinuti?
Originally submitted via email support on 2 January 2023. Migrated to the forum for community visibility.
For Dasduino CONNECT, the schematic and pinout are available. In Arduino IDE you should select ESP8266 or use the Soldered Board definition: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub
isprike, još uvijek radimo na dokumentaciji na soldered.com.
Za Dasduino CONNECT, šaljem Vam shemu i pinout u privitku. U Arduino IDE treba odabrati ESP8266 ili koristiti naš Board definition: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub
Attachment omitted in migration: Dasduino CONNECT Schematics.pdf
Attachment omitted in migration: Dasduino CONNECT.jpg
If the board were equipped with a solar panel and Li-ion battery, how would you recommend connecting them so the panel charges the battery when possible, with the battery supplying power when the solar panel cannot?
Hvala na odgovoru.
Ako bi sklop bi opremljen solarnim panelom i li-ion baterijom na koji nacin predlazete spajanje da bi panel punio bateriju kada to moze odnosno da baterija bude izvor kada solarni panel nije u mogucnosti?
An MPPT charger is not currently offered, which would be the ideal solution for this. For an alternative approach: connect the battery to the JST standard battery connector on the Dasduino board, and connect the solar panel to VCC. The board has an “auto select circuit” that will automatically choose the power source. Be careful not to exceed the maximum voltage for the VCC pin of 6V - use a panel rated for 6V.
Sve drugo je improvizacija. Možete bateriju priključiti na JST standardni konektor za nju na ploči Dasduino, a na VCC spojiti solarni panel. Na ploči se nalazi “auto select ciruit” koji će sam odabrati izvor napajanja. Samo pazite da ne pređete maksimalni napon za VCC pin od 6V, tj koristite panel s naponom od 6V.
