Dasduino CONNECTPLUS ESP32 wrong boot mode detected error on code upload
I have a Dasduino CONNECTPLUS (ESP32) and every time I try to upload code I get an error: Failed to connect to esp32: wrong boot mode detected(0xb)! The chip needs to be in download mode.
I’ve already tried changing the port, cable, and computer. I’ve checked the drivers and nothing helped. I also tried using the user button to enter download mode, but that didn’t work either.
How can I solve this problem?
Kupila sam vaš Dasduino CONNECTPLUS(ESP32) i svaki put kad pokušam uploadati kod pojavi se error koji glasi: Failed to connect to esp32: wrong boot mode detected(0xb)! The chip needs to be in download mode.
Već sam probala zamijeniti port, kabel i računalo. Provjerila sam drajvere i ništa nije pomoglo, pokušala sam i pomoću tipke user doći u download moad, ali bilo je uzalud.
Kako bi mogla riješiti svoj problem?
Originally submitted via email support on 17 August 2025. Migrated to the forum for community visibility.
Make sure you’re using the board definitions we’ve prepared for our boards. The full procedure is detailed in this tutorial: Arduino - Arduino Quick Start Guide | Soldered Documentation. Problems sometimes occur when certain pins on the board are connected to hardware incorrectly. Pay special attention to the IO2 pin – during code upload it must be disconnected and should not be connected to any external components. Try uploading code to the board when it’s connected only via USB-C cable.
Žao nam je što imate poteškoća. Prije svega, koristite li definicije pločica koje smo pripremili za naše boardove? Cijeli postupak detaljno je opisan u ovom tutorijalu: Arduino - Arduino Quick Start Guide | Soldered Documentation. Problemi se ponekad javljaju i kada su pojedini pinovi na pločici spojeni na hardver na neispravan način. Posebno obratite pažnju na IO2 pin – prilikom uploadanja koda mora biti odspojen i ne smije biti spojen ni na kakve vanjske komponente. Molimo vas da pokušate uploadati kod na pločicu kada je spojena samo putem USB-C kabela i javite nam rezultate.
I was able to solve the problem after disconnecting the component from the IO2 pin as you suggested.
Uspjela sam riješiti problem, nakon što sam odspojila komponentu s IO2 pina kao što ste rekli. Hvala.
-------- Izvorna poruka --------
Šalje: [name removed]
Datum: čet, 21. kol 2025. 11:02
Prima: [name removed]
