Dasduino ConnectPlus resets - use official ESP32 board definition
After replacing the board, the same problem persists. I’d like to know if I can get a contact number to reach someone.
I nakon zamjene pločice i dalje se javlja isti problem. Zanim me mogu li dobiti kontakt broj nekoga od Vas da Vas kontaktiram.
Originally submitted via email support on 8 September 2023. Migrated to the forum for community visibility.
I tested the SerialBT example on the board you returned and got a crash. I resolved it by using the official ESP32 board definition. Add this link to your ‘Additional Board Manager URL’s’: https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json, then select ‘ESP32 WROVER Module’. This is the official ESP32 board definition for that microcontroller and should be fully compatible with our board. I tested the Serial BT example and it works with this board definition.
I also tested the Serial BT example on one of our Dasduino Connect boards in development using that board definition and it worked OK. The issue was with the board definition in our library. Our board definition should be updated to include the latest ESP32 core - I’ve notified the team and it will be fixed soon. In the meantime, use the official ESP32 definition which should work the same (for pinout and everything else).
žao mi je čuti što je tako. Na žalost, support pružamo samo putem maila, ne telefonski.
U međuvremenu sam na pločicu koju si nam vratio probao uploadati SerialBT example i dobio crash na tvojoj pločici - uklonio sam problem tako što sam koristio službenu ESP32 verziju board definitiona. U ‘Additional Borad Manager URL’s’ stavi ovaj link: https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json , onda izaberi ‘ESP32 WROVER Module’. Ovo je službeni board definition od ESP32 za taj mikroupravljač i trebao bi biti u potpunosti kompatiblan sa našim boardom. Testirao sam Serial BT example i radi sa tim board definitionom.
Isprobao sam Serial BT example na jednoj našoj Dasduino Connect pločici koju imamo u razvoju koristeći taj board definition i također je radilo OK, ali bilo je isto tako problema sa board definitionom koji mi koristimo u našem libraryu. Ukratko, naš board definition bi trebalo updateati da sadržava najnoviji ESP32 core - javljam timu i rješiti će se što prije. U međuvremenu, koristi ESP32 službeni koji bi trebao raditi jednako (što se tiče pinouta i svega). Hvala ti što si nam javljanjem ukazao na ovaj problem.
