Dasduino ConnectPlus with accelerometer for vibration measurement project
I’m working on a diploma project for a vibration measurement sensor for the Faculty of Mechanical Engineering and Naval Architecture. I’m inquiring about the availability of the following components and their characteristics:
  • ESP32 with built-in Wi-Fi and if possible support for connecting to a Li-po battery and built-in USB programmer
  • 3-axis accelerometer module or vibration sensor that can measure low intensity vibrations compatible with ESP32 module
  • Li-po battery (if compatible with ESP32 or some module that would enable battery connection)
All components should be as small and compact as possible.
Radim na diplomskom projektu senzora za mjerenje vibracija za Fakultet strojarstva i Brodogradnje. Želio bih se raspitati o dostupnosti slijedećih dijelova i njihovih karakteristika koje bih nabavio od vas:
EPS32 sa ugrađenim wi-fi i po mogućnosti podrškom za spajanje na li-po bateriju i ugrađenim usb programatorom.
3-osni akcelerometar modul ili senzor vibracija koji može mjeriti mali intenzitet vibracija kompatibilni sa ESP32 modulom
Li-po baterija (ako je ESP32 kompatibilna ili neki modul koji bi omogućio spajanje baterije)
Sve komponente bi trebale biti što manje mase i dimenzija.
Zahvaljujem se unaprijed i radujem se vašem odgovoru.
LP [name removed]
Originally submitted via email support on 5 September 2022. Migrated to the forum for community visibility.
You can use Dasduino Connect with ESP8266 or Dasduino ConnectPlus with female headers which has ESP32. These can be connected to a Li-ion battery instead of a Li-po battery. Regarding accelerometer modules and vibration sensors - these are in development and unfortunately we cannot confirm when they will be available.
hvala Vam na upitu. Možete koristiti DASDUINO CONNECT - on ima ESP8266 ili DASDUINO CONNECTPLUS SA ŽENSKIM HEADERIMA - on ima ESP32. Oni se mogu spojiti na Li-ion bateriju umjesto Li-po baterije.
