I installed the CH340 driver and checked Device Manager, but the driver is not showing up where it should according to the documentation.
Pozdrav, naručio sam dasduino core i sada pokušavam sve namjestiti. Instalirao sam ch340 driver i kada odem u this pc->properties->device manager tamo bi trebao biti taj driver kao što je prikazano na slici u onom članku,ali meni toga i dalje nema. Hvala unaprijed na odgovoru i želim vam reći da su proizvodi super
Originally submitted via email support on 13 December 2024. Migrated to the forum for community visibility.
Regardless of Device Manager, does a COM port appear in the Arduino IDE? Under Tools > Ports there should be a COM port for the Dasduino Core that disappears from the menu when disconnected from USB. Does that work? If the port appears, you can select it and upload code.
hvala na lijepim riječima za Soldered proizvode
Bez obzira na device manager, pojavi li se COM port u Arduino IDE? Pod Tools >Ports bi trebao biti COM port Dasduino Core-a koji onda u tom istom izborniku nestane kad se iskopča iz USB-a. Radi li to? Ako se port pojavljuje, može se odabrati i može se raditi upload koda.
