I have a few questions about your products.
Is your Dasduino microcontroller board fully compatible with the classic Arduino microcontroller - its standard version? Is the programming concept and the ability to connect actuators, shields, sensors and other components exactly the same as on classic Arduino? How does your Dasduino differ from classic Arduino, if at all?
A few years ago you had Croduino boards in your range - why are they no longer available? As I recall, that microcontroller was completely identical to classic Arduino?
A few days ago we tried to use batteries and DC motors that we bought from you for a project. The products were:
https://soldered.com/hr/proizvod/baterija-cr2032/
Simply put: we tried to run the motor by connecting it to a battery placed in a suitable holder, also purchased from you. However, the motor would not start. I’m wondering: what’s the reason - is the current in the battery too small to run the motor? As I recall, we put two batteries in series, with a working voltage of 6 V, but the motor still wouldn’t start, while with an adjustable power supply I also bought from you, we were able to achieve it, but only at around 12 V, when we adjusted the potentiometer on the power supply itself.
I’m curious: what’s the reason for this?
Ispričavam vam se ukoliko sam vam već dosadio s pitanjima – baš sam često u kontaktu s vama u zadnje vrijeme.
Naime, zanimaju me određene pojedinosti glede proizvoda koje prodajete. 1. Je li vaša Dasduino mikrokontrolerska pločica u potpunosti odgovara klasičnoj izvedbi Arduino mikrokontrolera – njegovoj standardnoj verziji? Dakle, je li koncept programiranja i mogućnosti spajanja aktuatora, „shieldova“, senzora i ostalih popratnih elemenata potpuno jednak kao onome na klasičnom Arduinu? Dakle, po čemu se (ako uopće jest) se razlikuje vaš Dasduino od onog klasičnog Arduina? 2. Ta – koliko se sjećam, taj mikrokontroler je bio u potpunosti jednak klasičnom Arduinu? 3. Prije nekoliko dana smo bili pokušali iskoristiti baterije i DC motore koje smo sve bili kupili u vas za izradu nekog projekta. Riječ je o proizvodima: Motori i upravljači | Hardver u pokretu – Soldered Electronics https://soldered.com/hr/proizvod/baterija-cr2032/. Dakle, najjednostavnije rečeno: pokušali smo pokrenuti motor tako što smo ga spojili na bateriju koja je se nalazila u prikladnom kućištu, također nabavljeno od vas. Međutim, motor se nije htio pokrenuti. Zanima me: što je razlog tome: je li struja u bateriji premala za pokretanje motora? Koliko se sjećam, bili smo stavili u seriju dvije baterije, čiji je radni napon 6 V ali i dalje se motor nije htio pokrenuti, dok je to se podesivim izvorom napajanja kojeg sam također kupio u vas to bilo ostvarivo, ali opet: tek na nekakvih 12 V, kada smo podesili taj potenciometar na samom izvoru napajanja. Zanima me: što je razlog tome? Lijep vam pozdrav, [name removed]
Originally submitted via email support on 10 December 2024. Migrated to the forum for community visibility.
