Dasduino Core not uploading to Arduino IDE - CH340C driver and board selection
I received a Dasduino Core ATMega 328 today, but I can’t connect it to Arduino IDE. I added the board definitions JSON link to the correct location at https://github.com/SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE/raw/master/package_Dasduino_Boards_index.json. It loads 4 possible setups but I can’t get upload to work on any of them - the board isn’t recognized. I must be making a simple mistake somewhere. I also tried with an Arduino UNO but it won’t allow upload there either.
Poštovani, danas je stigao DD Core ATMega 328, no na žalost ga ne mogu spojiti na Arduino IDE. Link je stavljen gdje treba na https://github.com/SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE/raw/master/package_Dasduino_Boards_index.json , učitava 4 moguća setup-a ali niti na jedan ne uspjevam napraviti upload (ne prepoznaje board). Sigurno negdje banalno griješim :frowning:
Probao sam i sa Arduino UNO , ali niti ovdje ne dozvoljava upload. Help :slight_smile:
Originally submitted via email support on 3 March 2026. Migrated to the forum for community visibility.
It’s possible this isn’t your fault since the driver installation isn’t mentioned anywhere in our documentation (theoretically nothing should need to be installed, but you know how Windows can be - nothing should be left to theory). You can download the drivers for the CH340C chip that’s on the Dasduino from this link: https://cdn.sparkfun.com/assets/learn_tutorials/8/4/4/CH341SER.EXE
This component converts USB signals to UART so the computer and board can communicate. Try installing this first and let us know the results - we can troubleshoot further if needed.
Moguće je da uopće nije vaša krivica pošto u našoj dokumentaciji ne vidim da je igdje spomenuta instalacija drivera (teoretski se ne bi trebalo ništa instalirati, ali kakav Windows zna biti, ništa ne treba prepustiti teoriji ;)). Preko slijedećeg linka možete preuzeti drivere za CH340C koji se nalazi na Dasduinu: https://cdn.sparkfun.com/assets/learn_tutorials/8/4/4/CH341SER.EXE
Spomenuta komponenta služi za pretvaranje USB signala u UART kako bi računalo i pločica mogli komunicirati, pa vrijedi ovo prvo isprobati.
Javite se sa rezultatima pa možemo daljnje troubleshootat ako bude potrebno!
Either I’m obviously making a mistake somewhere or I selected the wrong DDINO board type. I’m getting this error:
C:\Users\[user]\AppData\Local\arduino\sketches\463B5648718DDCB5689114FE31772ED7\sketch\Blink.ino.cpp:1:10: fatal error: Arduino.h: No such file or directory
#include
compilation terminated.
exit status 1
Josipe, ili ja očigledno negdje griješim ili sam odabrao krivi DDINO ugl, ovo je greška
C:\Users[user]\AppData\Local\arduino\sketches\463B5648718DDCB5689114FE31772ED7\sketch\Blink.ino.cpp:1:10: fatal error: Arduino.h: No such file or directory
#include
exit status 1
Got it working! I selected NULA CORE and was able to upload a basic sketch with it. Hopefully that’s the solution.
Josipe….opaaaa…izgleda da sam uspio
:blush:))
Odabrao sam NULA CORE i s njim uspio upload basic datoteke.
Nadam se da je to to
:blush:
That’s it! Good luck with the rest of your project and let us know if you have any questions.
To je to! Sretno sa ostatkom projekta i javite ako bude pitanja :wink:
