Does Dasduino CORE have a 5V operating voltage? Specifically, is it possible to have a board with 5V output on the pins so I can control a 5V relay?
proizvodite li plocicu tipa Dasduino CORE koja ima radni napon 5V?
Odnosno da li je moguce imat plocicu koja ima izlazni napon na pinovima 5V kako bi mogla upravljati relejem od 5V
Originally submitted via email support on 27 February 2026. Migrated to the forum for community visibility.
Dasduino CORE will be rebranded as NULA Core, with the same Atmega328p microcontroller and a logic level output of 5V.
hvala na upitu, Dasduino CORE će se promijeniti u NULA Core, sa istim Atmega328p mikroupravljačem i izlazom (logic levelom) od 5V.
What voltage does the Dasduino CORE board you mentioned output on the digital pins? We previously bought one board from you and it seemed to have 3.3V. The English version of the product description says the board operates at 5V, while the Croatian version says “Designed for 3.3V”. We need 5V output on the pins.
Ova pločica na koju se referirate (DASDUINO CORE), koji napon daje na izlaznim digitalnim pinovima? Prethodno smo kupili jednu pločicu kod vas i čini nam se da je napon bio 3.3V. U opisu proizvoda na engleskoj verziji stranice piše da pločica radi na 5V, dok je na hrvatskoj verziji “Dizajn je za 3.3V” Nama treba izlazni napon na pinovima od 5V Hvala na odgovoru Pozdrav dipl.ing [name removed] direktor
Furki Sport d.o.o.
Našička 5, Zagreb
M: E: [email removed]; [email removed]
www.furkisport.hr
Dasduino CORE and COREPLUS output 5V on the pins. ESP32 boards output 3V3. Could you send me the product link so I can correct the error?
Dasduino CORE i COREPLUS na pinovima daju 5V. ESP32 pločice su 3V3.
Možeš li mi molim te poslati link od proizvoda da mogu ispraviti grešku?
I placed an order. Can you please verify that I ordered correctly and that it will have 5V on the outputs? I notice the English and Croatian descriptions differ regarding voltage at Browse All Categories | Soldered
Mozete li molim Vas provjeriti da li sam dobro narucio I da ce biti 5V na izlazima? p.s. Browse All Categories | Soldered na ovom linku mi se cini da je engleski I hrvatski opis drukciji sto se tice napona Puno hvala dipl.ing [name removed] direktor Furki Sport d.o.o. Našička 5, Zagreb M: E: [email removed]; [email removed] www.furkisport.hr
Attachment omitted in migration: ~WRD0003.jpg
Yes, Dasduino CORE will output 5V on the pin when digitalWrite HIGH is called on that pin. Thank you for the order and for pointing out the description discrepancies - it helps us improve how our products are presented.
da, to je to, Dasduino CORE će dati na pinu 5V kada se pozove digitalWrite HIGH na tom pinu.
Hvala na narudžbi i na uvidu za opise, to nam pomaže da proizvodi budu još bolje predstavljeni.
