Dasduino Core programming in Visual Studio Code with C
How do I configure the Dasduino Core board to program it in C?
Dobar dan, znate li možda kako konfigurirati dasduino core pločicu tako da ju mogu programirati u jeziku C? Bio bih vam jako zahvalan.
Originally submitted via email support on 2 August 2025. Migrated to the forum for community visibility.
We officially support Arduino IDE, which is technically C++ but C code is compatible with it. You can use this tutorial to program Dasduino CORE in VSCode and use Arduino IDE just for upload: Arduino - Using VSCode with Arduino | Soldered Documentation
If you want to use strictly C, you can manually use GCC and AVRDude for upload. You might find PlatformIO best for this. We don’t officially support it, but the process is the same as for Arduino Nano/UNO: Arduino Uno — PlatformIO latest documentation
hvala ti na upitu! Mi službeno podržavamo Arduino IDE koji je tehnički C++ ali C kod je kompatibilan s time. Možeš koristiti ovaj tutorial kako bi programirao Dasduino CORE u VSCodeu i samo koristio Arduino IDE za upload: Arduino - Using VSCode with Arduino | Soldered Documentation
Ako želiš koristiti striktno C, možeš si ručno koristiti GCC i AVRDude za upload. Možda ti je najbolje koristiti PlatformIO. Ne podržavamo ga službeno ali postupak je isti za Arduino nano/UNO: Arduino Uno — PlatformIO latest documentation
Nadam se da to pomaže!
