When attempting to upload a sketch from the Arduino IDE to a Dasduino CORE board, I get the error: Property ‘upload.tool.serial’ is undefined. I have followed all instructions on the product page and installed the Arduino IDE Board definition. I have also tried with different Arduino IDE versions (1.8.18, 2.0.3, 2.3.2), and the same error appears in all of them.
Prilikom pokušaja upload-a skice iz Arduino IDE sučelja na pločicu Dasduino CORE javlja se sljedeća greška: Property ‘upload.tool.serial’ is undefined. Sljedio sam sve upute na vašoj stranici i instalirao Arduino IDE Board definition. Također, pokušao sam sa različitim verzijama Arduino IDE sučelja (1.8.18, 2.0.3, 2.3.2). U Svim verzijama sučelja javlja mi se ista greška.
Originally submitted via email support on 29 May 2024. Migrated to the forum for community visibility.
This should work in version 1.8 (I have seen this exact error appear on some machines in 2.0).
Obvious question but have you selected the board definition in the Tools menu after installation?
Sometimes this kind of problem can be resolved by reinstalling the board definition and clearing the cache:
Close Arduino IDE. Before making any changes, close Arduino IDE to avoid potential issues with files that are currently in use.
Find the Arduino15 folder. The location of the Arduino15 folder depends on your operating system:
- Windows: C:\Users[user]\AppData\Local\Arduino15
- MacOS: /Users/[username]/Library/Arduino15
- Linux: /home/[username]/.arduino15
Open the Arduino15 folder. Navigate to the appropriate folder using File Explorer (Windows), Finder (MacOS), or terminal (Linux).
Delete board definitions. In the Arduino15 folder you will find folders containing board definitions. Typically these are folders such as packages, staging, and hardware.
- packages contains all board definitions downloaded through Boards Manager.
- staging contains temporary download files.
- hardware may contain manually installed board definitions.
You can delete the entire contents of the packages and staging folders, as well as specific board definitions within the hardware folder if you know which ones you want to remove.
Delete Arduino cache. The Arduino cache is also located in the Arduino15 folder, often in the form of temporary files and folders. You can delete the entire contents of the cache folder within Arduino15:
- cache contains temporary files that Arduino uses to speed up recompilation and other tasks.
Restart Arduino IDE. After you have deleted the necessary files and folders, restart Arduino IDE. The IDE will re-download the board definitions you need when you request them through Boards Manager.
Try this and report back if it works after reinstalling (but definitely try on Arduino 1.8).
žao mi je što imaš ovaj problem. Ovo bi trebalo raditi u verziji 1.8 (osobno sam vidio da na nekim računalima se točno ta greška javlja na nekim računalima u 2.0).
Možda očito pitanje ali jesi li izabrao board definition u Tools izborniku nakon instalacije? Evo kako meni izgleda tools izbornik:
Nekad će se ovakav problem ukloniti sa reinstalacijom board definitiona i brisanjem cachea:
- Zatvori Arduino IDE Prije nego što započneš bilo kakve promjene, zatvori Arduino IDE kako bi izbjegao eventualne probleme s datotekama koje su trenutno u uporabi.
- Pronađi Arduino15 folder Lokacija Arduino15 foldera ovisi o operacijskom sustavu:
Windows:C:\Users\ \AppData\Local\Arduino15 MacOS:/Users/ /Library/Arduino15 Linux:/home/ /.arduino15 Zamijeni svojim stvarnim korisničkim imenom.
- Otvori Arduino15 folder Navigiraj do odgovarajuće mape pomoću File Explorera (Windows), Finder-a (MacOS), ili terminala (Linux).
- Obrisi board definicije U Arduino15 folderu naći ćeš mape koje sadrže board definicije. Tipično su to mape kao što su packages, staging i hardware.
packages sadrži sve board definicije preuzete kroz Boards Manager. staging sadrži privremene datoteke preuzimanja. hardware može sadržavati ručno instalirane board definicije. Možeš obrisati cijeli sadržaj packages i staging mapa, kao i specifične board definicije unutar hardware mape ako znaš koje želiš ukloniti.
- Obrisi Arduino cache Arduino cache se također nalazi u Arduino15 folderu, često u obliku privremenih datoteka i mapa.
Možeš obrisati cijeli sadržaj cache mape unutar Arduino15:
cache sadrži privremene datoteke koje Arduino koristi za ubrzanje ponovnog kompiliranja i drugih zadataka. 6. Ponovno pokreni Arduino IDE Nakon što si obrisao potrebne datoteke i mape, ponovno pokreni Arduino IDE. IDE će ponovno preuzeti board definicije koje su ti potrebne kad ih zatražiš kroz Boards Manager.
Probaj ovo i javi ako nakon ponovne instalacije radi (ali obavezno probaj na Arduino 1.8).
