Dasduino Core WiFi connectivity options
Can I use the Dasduino Core to connect to a WiFi hotspot?
Originally submitted via email support on 26 October 2023. Migrated to the forum for community visibility.
The Dasduino Core doesn’t have built-in Wi-Fi capabilities. You would need to use a WiFi breakout board and communicate with it to connect to WiFi.
If you need built-in WiFi, the Dasduino Connect and ConnectPlus both have built-in WiFi that works out of the box and is simple to use in code.
