I purchased the Dasduino Hobby Set. The programming information is clear on your website, but I haven’t found electrical schematics and connection instructions. I need to know what to connect where, where the positive and negative voltage go, and what projects can be made with this set. Could you provide links to electrical schematics and wiring guides? I have a 10-year-old son who shows strong interest in this, and I’d like to help him get started.
Dobra večer
Kupili smo vaš set DASDUINO HOBBY .
Što se tiče programiranja sve je jasno i ima na vašim stranicama.
No po električnim shemama i spajanjima nisam našao, što gdje priključiti, gdje je napon + i – , kakve stvari možemo napraviti sa ovim setom.
Ako možete pošaljite linkove sa električnim shemama i uputstvima za spajanje.
Imam sina od 10 godina koji pokazuje jak interes, pa bi mu volio olakšati.
Originally submitted via email support on 15 January 2024. Migrated to the forum for community visibility.
Here’s also a good unofficial site with many project ideas: Loading
YouTube also has good tutorials on this, which may be easier to follow in video format.
Searching for how to do things, using search engines, and problem-solving this way are essential parts of learning programming and electronics. I mention this so you won’t get discouraged—it’s wonderful to hear about interest in electronics at that age, and I hope your son continues. We’re here for any additional specific questions you have about components.
za sheme i ideje što napraviti preporučujem dio stranice ‘članci’ na našoj službenoj stranici: https://soldered.com/hr/blog/
Evo i jedne dobre neslužbene stranice s hrpom ideja za projekte: Loading
Siguran sam kako i YouTube isto ima dobrih tutoriala za ovo, koji su možda lakši za pratiti jer je u video formatu.
Traženje kako se nešto radi, guglanje i takvo rješavanje problema je sastavni dio programiranja i učenja o elektronici. To samo napominjem kako se ne bi obeshrabrili, za interes u elektroniku u toj dobi je stvarno lijepo čuti i nadam se da će sin nastaviti. Ovdje smo za sva dodatna pitanja, ako budeš imao nekih specifičnih za komponentu.
