I’m planning a project to make an automatically opening box and would like your help and opinion.
Something like this: Automatically Opening / Closing a Box With a Linear Actuator and Arduino : 5 Steps (with Pictures) - Instructables
My project would consist of a similar box with an LCD display mounted on top, 2 buttons, and potentially several LEDs, with the controller on the inside along with the motor. I’m considering this component configuration and would like help:
1x LED display – 000061 or another you recommend (333100)
1x motor – 109042 or 101246 – it needs to open the box, I assume choosing the first one gives me the add-ons needed for such movements?
1x controller – 333225 – I think Dasduino LITE (ATTiny1604) will be sufficient – with male header – and I’m curious how long the USB-C cable is?
1x power supply – 100717
5x LED diodes – 100105 (do I need a special voltage regulator to light a specific color – given that the voltages are lower, or does the controller have this capability?)
2x buttons – 101111
If I forgot something, please suggest it.
imam u planu napraviti projektić za otvaranje kutijice i molio bih za Vašu pomoć / mišljenje.
Nešto na foru ovoga:
Moj projektić bi se sastojao od slične kutije na koju bi s gornje strane ugradio LCD display, 2 tipkala i potencijalno nekoliko LED-ica, a kontroler bi se nalazio s unutarnje strane, kao i motor… po nekoj konfiguraciji išao bih s ovim komponentama pa bih molio pomoć:
1x LED display – 000061 ili neki drugi koji preporučate (333100)
1x motorić – 109042 ili 101246 – trebao bi otvarati tu kutiju, pretpostavljam da izbor prvoga mi omogućava dodatke koji su potrebno za takve kretnje?
1x kontroler – 333225 – mislim da će Dasduino LITE (ATTiny1604) biti dovoljan – s muškim headerom – i zanima me koliko je dugačak USB-C kabel?
1x napajanje – 100717
5x LED diode – 100105 (treba li mi posebni regulator napona kako bi palio određenu boju – s obzirom da su naponi niži ili kontroler ima tu mogućnost?)
2x tipkala – 101111
Ukoliko sma nešto zaboravio, molim sugestiju.
Originally submitted via email support on 13 October 2024. Migrated to the forum for community visibility.
