I recently assembled the Dasduino Make yourself kit and tested it. My computer recognizes it and the purple LED on it lights up, but I cannot upload a program to it. How can I upload a program to it?
Nedavno sam kupio vaš (DASDUINO MAKE YOURSELF KIT). Zalemio sam ga i isprobao. Moje računalo njega prepozna i ljubičasta led-dioda na njemu svijetli, ali ne mogu nikako prebaciti program na njega. Kako mogu prebaciti program na njega?
Originally submitted via email support on 25 November 2024. Migrated to the forum for community visibility.
Have you selected Dasduino Core as the board definition in the Arduino IDE? In the README of this repository you can see a tutorial on how to install Dasduino boards in your Arduino program. Once you have them installed, simply select Dasduino Core as the board and then try uploading a blank sketch.
You may need to install drivers for serial communication. There is a tutorial for that here: https://soldered.com/hr/learn/instalacija-ch340-drivera-croduino-basic3-nova2/
Let me know if it works.
jesi li u Arduino IDE-u odabrao Dasduino Core kao board definition? U README-ju ovog repozitorija možeš vidjeti tutorial kako instalirati Dasduino pločice u svoj Arduino program. Kad ih imaš instalirano, samo odaberi Dasduino Core kao board i onda probaj uploadati prazan sketch.
Možda moraš instalirati drivere za serijsku komunikaciju, za to postoji tutorial ovdje: https://soldered.com/hr/learn/instalacija-ch340-drivera-croduino-basic3-nova2/
Javi ako proradi
pa ćemo vidjeti što dalje.
