I received a Dasduino beginner set. On first power-up, the LED connected to pin D8 was fading in and out with a purple color. After uploading my first program, the fade effect stopped and it just stayed lit (as expected, since the code was replaced). However, the next day the LED stopped working entirely. No matter what I send to pin D8, it has no effect. Is it possible the LED burned out, or am I sending the signals incorrectly?
nedavno sam kod vas naručio Dasduino set za početnike. Kod prvog uključivanja je na njemu LED dioda spojena na D8 svijetlila ljubičasto fade-in/fade-out. Nakon uploada prvog programa je prestao fade-in efekt, i samo je svijetlila (očekivano, jer je kod prebrisan). Međutim, dan poslije ta LED-ica uopće ne svijetli, i što god da pošaljem na pin D8 nema efekta. Je li moguće da je pregorila, ili krivo šaljem signale na nju.
Ako postoji online dokumentacija za ovo ili neki FAQ koji mi je promakao, slobodno proslijedite.
Hvala i lp
Originally submitted via email support on 6 December 2023. Migrated to the forum for community visibility.
