Dasduino upload fails and soldering temperature for relay and LCD
I have a relay with pins that need to be soldered. What temperature should I use to solder the relay? Should the LCD screen be soldered at the same temperature? I’m also having a problem with Arduino IDE - when I write a program for Dasduino, it won’t upload to the board.
ja sam Nikola, hvala Vam na poklonu jako mi se svidio paket.
U paketu je bio relay sa pinovima koje treba zalemiti. Na kojoj temperaturi treba zalemiti relay? I da li se na istoj temperaturi lemi LCD ekran? Imam problem sa Arduino IDE kada napišem program za Dasduino nikada mi neće prebacit program na Dasduino.
Originally submitted via email support on 31 August 2023. Migrated to the forum for community visibility.
We typically set our soldering irons to 350°C. The LCD screen is soldered at the same temperature.
For Arduino IDE, you need to install the Dasduino board definitions. Arduino IDE needs to know which board you have so it can correctly compile the code for that specific board type. Here’s how to add it:
Add this URL: https://github.com/SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE/raw/master/package_Dasduino_Boards_index.json
  1. Launch Arduino IDE
  2. Go to File > Preferences
  3. In the Preferences window, find the “Additional Boards Manager URLs” field
  4. Enter the URL above in that field
  5. Click OK
  6. Now open Tools > Board Manager, and you should see the Dasduino boards (search for them if you don’t see them immediately)
  7. Install the Dasduino boards
  8. When uploading your sketch, select the correct model of your board
Now a basic blink sketch should work. Let me know if you have any problems with this.
obično mi svoje lemilice podešavamo na 350°C. Na istoj temperaturi se lemi LCD ekran.
Što se tiče Arduino IDE-a, moraš instalirati Dasduino board definitione. Arduino IDE u biti treba znati koju pločicu ti imaš kako bi on mogao točno ‘zapakirati’ kod za tu vrstu pločice. Evo kako ga dodati:
Ovo je URL koji trebaš dodati: https://github.com/SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE/raw/master/package_Dasduino_Boards_index.json
Pokreni Arduino IDE. Idi na “Datoteka” (File) > “Postavke” (Preferences). U prozoru “Postavke”, potraži polje “Dodatni URL-ovi upravitelja ploča” (Additional Boards Manager URLs). U to polje, unesi URL koji želiš dodati (to je ovaj iznad). Klikni “U redu” (OK) Sada, otvori “Alati” (Tools) > “Upravitelj ploča” (Board Manager), i trebao bi vidjeti Dasduino ploče (ako ih ne vidiš, pretraži ih) Instaliraj Dasduino ploče, i pri uploadu sketcha, izaberi točan model svoje ploče
Sada bi neki osnovni ‘blink’ kod trebao raditi. Javi ako imaš bilo kakvih problema s ovim.
