Hello,
I’m designing a small open-source handheld device and would like to use your Li-Po Battery 800mAh 3.7V 802540 JST (SKU 333430):
https://soldered.com/collections/batteries-holders/products/li-po-battery-800mah-3-7v-802540-jst
Before I finalise the PCB and enclosure, could you send me the following?
- Cell datasheet: rated and minimum capacity, charge voltage, and the standard and maximum charge current.
- Discharge limits: maximum continuous and peak discharge current.
- Protection circuit thresholds: overcharge, overdischarge and overcurrent/short-circuit trip values.
- Charge temperature range recommended for the cell.
- Exact dimensions with tolerances:
- Does the 40 mm length include the protection PCB?
- What is the maximum thickness, including allowance for swelling?
- What is the wire length?
- Safety data sheet (MSDS/SDS) and UN 38.3 test summary: I’ll be shipping assembled devices with the battery installed, and couriers ask for both. Your documentation mentions the SDS is available on request.
- CE and UKCA declarations for SKU 333430. This SKU isn’t in the table on Li-Ion Battery - Hardware details | Soldered Documentation, and CE-333430.pdf returns a 404 there.
- If available, an IEC 62133 test report or certificate for the cell.
I can confirm the JST-PH polarity (red = +) from your documentation, so that part is clear.
Thank you ![]()
