Day/night switch for 12V LED light with minimal power consumption
Looking for an electronic switch to turn on an LED light at night and turn it off during the day. The light replaces a 12V/10W automotive bulb. Everything is powered by a 12V battery, and minimal power consumption is essential since the switch needs to operate daily and ideally the battery should last at least 14 days. Alternatively, a lower-power LED could be used instead.
Traži se sklopka /prekidač (elektronički) za uključenje LED žarulje
(zamjena za 12V/10W auto žarulju !) po noći , tj.
isključenje KLED svjetla danju. Sve se napaja iz Akku 12V
i potrebna je minimalna potrošnja jer je uključenje predviđeno svakodnevno, minimalno
bi moralo trajati 14 dana uz raspoloživ Akku 12C7 25 Ah.
Moguće je i zamjeniti LED sa nekim koji manje troši.
Originally submitted via email support on 3 September 2016. Migrated to the forum for community visibility.
Just to clarify: you’re looking for an automated day/night switch that turns on at night and deactivates during the day for a load of around 1-2W (an LED replacement)?
Correct, a day/night switch. The 10W bulb has been replaced with an appropriate LED (LED with the same socket for 12V) so we’re talking about approximately 1-2W power consumption. Unfortunately I don’t know the exact specification—I would need to check the LED in use.
Točno, prekidač dan/noć, no ne 10W snage žarulje, već
Je takva žarulja zamjenjena adekvatnom LED žaruljom (LED diodama sa istim grlom za 12V)
pa se dakle radi o cca 1-2 W snage LED-a. Nažalost ne znam točno, morao bih pogledati LED koji korstim.
Lp [name removed]
We don’t have a ready-made solution, but we have a very simple circuit that will do what you need: Dark/Light sensor using transistor – BuildCircuit.COM
Instead of BC547 you can use 2N2222 (which we stock) and the power supply can be 12V. You will need a light-dependent resistor (LDR) and several resistors.
nažalost nemamo nekakvo gotovo rješenje, ali imamo super-jednostavan strujni krug koji će odraditi ono što trebate: Dark/Light sensor using transistor – BuildCircuit.COM
Umjesto BC547 možete koristiti 2N2222 (kojega imamo na webshopu) i izvor napajanja može biti 12V. Trebat ćete fotootpornik i nekoliko otpornika.
