I have a DRV84 driver with a damaged Zener diode (D2). After desoldering it, the driver still works as expected. Can I continue using it without the diode as long as I don’t connect the FAULT pin? Should I expect any further damage? Alternatively, could any other 3.3V Zener diode with similar dimensions work as a replacement?
Originally submitted via the contact form on soldered.com on 11 February 2025. Migrated to the forum for community visibility.
The driver will work without the diode if you don’t connect more than 3V3 to the SLEEP pin.
I applied 5V to the SLEEP pin without realizing it was connected to D2, which fortunately caused no issues. I destroyed D2 by connecting FAULT to 5V directly, resulting in smoke from the diode. I assume any SMD 3.3V Zener diode will work as a substitute.
Looking at the schematic, the SLEEP pin is the one affected by the Zener diode. You can use essentially any Zener diode with a Vz of 3V3, which should be very common.
I soldered in a new Zener diode (SOT-23, marked Z14). Everything works correctly now.
