I need help with NO sensor calibration on the Electrochemical Gas Sensor module. NO2 works fine but requires further tuning. Can you provide the NO sensor configuration?
Originally submitted via the contact form on soldered.com on 28 July 2025. Migrated to the forum for community visibility.
The latest version of the Arduino library includes the NO sensor configuration at: Soldered-Electrochemical-Gas-Sensor-Arduino-Library/src/sensorConfigData.h at 7123e096d8bf6e0cdc776a2c7360d2996dee216f · SolderedElectronics/Soldered-Electrochemical-Gas-Sensor-Arduino-Library · GitHub
Try the latest library version with this sensor configuration using the singleSensor.ino example. The configurations are based on the datasheet but we haven’t been able to test it precisely, so your feedback will help us determine if further adjustments are needed.
