Does the ESP32-WROOM-32D come with pins so it can be placed directly into a breadboard?
WiFi & Bluetooth | Wireless IoT Hardware – Soldered Electronics
Dali traženi proizvod dolazi sa pinovima da se može staviti direktno u breadboard?
Zahvaljujemo.
Originally submitted via email support on 25 March 2023. Migrated to the forum for community visibility.
The product comes as shown in the image, without pins.
proizvod dolazi takav kakav je na slici, bez pinova.
Can the pins be purchased separately and what options are available?
Dali se pinovi mogu kupiti odvojeno i koja je cijena?
There are pin options available, but note that the original design is not intended to be connected that way and may not fit breadboards optimally. You will need to omit the pins that run across the module due to how breadboards are designed, and connect those separately if you need any of them.
Postoji ovako nešto, ali imajte na umu da orginalno to nije namijenjeno da se spaja na takav način te neće možda najbolje pasati na breadboard. Svakako ćete morati izostaviti pinove koji idu popreko zbog načina na koji je breadboard dizajniran pa njih spojite na neki drugi način ako Vam je baš koji od tih potreban.
