ESP8266 MOD07 vs MOD12 differences and flexible WiFi credentials
I recently purchased an ESP8266 MOD07 controller. I have two questions:
  1. What is the difference between ESP8266 MOD07 and ESP8266 MOD12?
  2. How can I make the SSID and password flexible - in other words, how do I write code so the SSID and password are not hardcoded in the program, but can be changed and rewritten from a mobile device?
I also want to understand what the EEPROM command does. I encountered it while researching how to solve the above problem.
Kupili smo kod Vas nedavno kontroler esp8266 mod07. Zanimaju nas dvije stvari:
  1. Koja je razlika između esp8266 mod07 i esp8266 mod12
  2. Kako da napravim mogućnost fleksibilnosti SSID i LOZINKE, drugim riječima, kako da napravim program da mi ssid i lozinka nisu upisani u programu, već ih ja mogu mijenjati i ponovno upisivati preko mobilnog uređaja?
    Zanima me još znati li ćemu služi naredba EEPROM, koju sam pokušavajući riješiti gore navedeni problem, uočio da ljudi koriste…
Hvala do idućeg mail-a.
Originally submitted via email support on 5 March 2018. Migrated to the forum for community visibility.
  1. See the details for ESP12 and ESP07 at the links below to compare them. There are no significant differences besides dimensions and antenna connector type.
    http://www.esp8266.com/wiki/doku.php?id=esp8266-module-family#esp-07
    http://www.esp8266.com/wiki/doku.php?id=esp8266-module-family#esp-12
  2. For the described functionality, use the WiFiManager library: GitHub - tzapu/WiFiManager: ESP8266 WiFi Connection manager with web captive portal · GitHub
  3. EEPROM is memory for variables that persists after the device is powered off or loses power. Think of it like a small hard drive (as opposed to RAM).
  1. pogledajte detalje ESP12 i ESP07 na linkovima ispod pa možete usporediti. Neke značajne razlike osim dimenzija i konektora za antenu nema.
  2. za navedenu funkcionalnost koristite WiFi Manager library: GitHub - tzapu/WiFiManager: ESP8266 WiFi Connection manager with web captive portal · GitHub
  3. EEPROM je memorija za varijable koja se ne gubi nakon gašenja uređaja/nestanka napajanja. Zamislite ju kao mali hard drive(za razliku od RAM)
