ESP8266 module connection guide for Croduino
Where can I find materials or scripts to help connect an ESP8266 module to the internet for use with Croduino?
Pozdrav, narucili smo nedavno kod vas ESP866 MODULE za spajanje kroduina sa internetom.
Zamolili bi vas ako imate/možete poslati nekakve materijale ili skripte za lakse spajanje sa internetom
hvala unaprijed
Originally submitted via email support on 26 January 2017. Migrated to the forum for community visibility.
Which ESP module model do you have?
koji model ESP modula imate?
Here are some resources that should help. This is the ESP pinout so you can see all the labeled pins: http://www.esp8266.com/wiki/lib/exe/fetch.php?cache=&w=700&h=666&tok=8349ac&media=07-06.jpg
The ESP requires special connection setup - you need to pay attention to certain pins for it to work properly. This is a good tutorial showing the connections: http://www.esp8266.com/wiki/doku.php?id=getting-started-with-the-esp8266
You can program it from Arduino by adding a custom board that works the same way as Croduino NOVA: https://e-radionica.com/hr/blog/2016/01/31/kako-programirati-croduino-nova-iz-arduino-softwarea/
Because the ESP8266 is a good chip but complicated to handle and connect, we created a board with it that is really simple to work with.
evo neliko stvari, nadam se da će biti korisno. Ovo pinout ESP-a, što znači da možete vidjeti sve pinove označene: http://www.esp8266.com/wiki/lib/exe/fetch.php?cache=&w=700&h=666&tok=8349ac&media=07-06.jpg
Nadalje, ESP morate posebno povezati, morate paziti na određene pinove kako bi dobro radio. Ovo je dobar tutorijal gdje se vidi konekcija: http://www.esp8266.com/wiki/doku.php?id=getting-started-with-the-esp8266
Možete ga programirati iz Arduina, trebate dodati “custom board” koji je isti kao i za Croduino NOVA: https://e-radionica.com/hr/blog/2016/01/31/kako-programirati-croduino-nova-iz-arduino-softwarea/
Baš zbog toga što je ESP8266 dobar chip, ali kompliciran za baratanje i povezivanje, napravili smo pločicu s njime s kojom je stvarno jednsotavno raditi: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
