ESP8266 module connection to Dasduino CORE
I need help connecting an ESP8266 module with a Dasduino CORE. I’ve created a custom PCB for easier wiring. I want to know if the module needs to be flashed or if it’s plug and play. I’ve added the ESP8266 library to Arduino IDE alongside the Dasduino library and copied both JSON files into preferences. Is there anything else I need to do, or should this work as is?
Spojio bi dasduino core sa esp8266 modulom. Izradio sam tiskanu pločicu za modul radi lakšeg povezivanja sa kablićima. Zanima me dali se modul koji sam kupio kod vas mora flash-ati ili je on plu and play verzija. U arduini IDE sam ubaci librari za esp8266 isto kao i za dasduino, u preferenses sam iskopirao jsone i za esp 8266 i za dasduino. Dali treba još nešto napraviti ili bi to trebalo tako raditi.
Originally submitted via email support on 8 April 2025. Migrated to the forum for community visibility.
The module definitely needs a logic level converter because the ESP8266 operates at 3.3V logic level while the Dasduino CORE operates at 5V.
Here’s how to connect Dasduino CORE and ESP8266:
Wiring:
  • Dasduino GND to ESP8266 GND
  • Dasduino 3.3V to ESP8266 VCC
  • Dasduino RX (e.g., D2) to ESP8266 TX (through level shifter)
  • Dasduino TX (e.g., D3) to ESP8266 RX (through level shifter)
Warning: ESP8266 uses 3.3V logic – connecting 5V TX from Dasduino directly can damage it. Use a logic level shifter: Logic Level Converter Board – Soldered Electronics
Software – Arduino code
In Arduino IDE, add SoftwareSerial:
#include <SoftwareSerial.h>
SoftwareSerial espSerial(2, 3); // RX, TX pins, for example 2 and 3, you can use any others
void setup() {
  Serial.begin(9600);
  espSerial.begin(9600);
  Serial.println("Starting communication with ESP8266...");
  espSerial.println("AT"); // test communication
void loop() {
  if (espSerial.available()) {
    Serial.write(espSerial.read());
  if (Serial.available()) {
    espSerial.write(Serial.read());
Open Serial Monitor (9600 baud), set “Both NL & CR” and test with AT. If it returns OK, the connection with ESP8266 is established.
Connecting to WiFi network
After AT, enter the following commands:
AT+CWMODE=1
AT+CWJAP="wifi_network_name","password"
If successful, it returns WIFI CONNECTED.
Sending HTTP request (GET example):
AT+CIPSTART="TCP","example.com",80
AT+CIPSEND=47
GET / HTTP/1.1
Host: example.com
Tips: If ESP doesn’t respond, check power supply and logic levels. A 1000 µF capacitor near ESP power supply is recommended to smooth out power supply irregularities. This is a basic tutorial – let me know if ESP8266 responds to the “AT” command. If not, try 115200 baud rate. If it still doesn’t respond, the AT-commands sketch may need to be flashed to the ESP8266, which I can help with if we determine that’s the issue.
sad razumijem, modul svakako treba logic level converter jer esp 8266 radi na 3v3 logic levelu dok Dasduino CORE radi na 5V.
Evo tutoriala za spajanje Dasduino CORE-a i esp8266 modula:
Naravno! Evo kratkog, direktnog i konstruktivnog tutoriala za korištenje ESP8266 WiFi modula s Dasduino CORE (ATmega328P):
:gear: Povezivanje Dasduino COREESP8266GNDGND3.3VVCCRX (npr. D2)TX (preko level shiftera!)TX (npr. D3)RX (preko level shiftera!):warning: Napomena: ESP8266 koristi 3.3V logiku – direktno spajanje 5V TX iz Dasduina može ga oštetiti! Treba koristiti logic level shifter kao što je ovaj: Logic Level Converter Board – Soldered Electronics
:laptop: Softver – Arduino kod U Arduino IDE-u, dodaj SoftwareSerial: #include
SoftwareSerial espSerial(2, 3); // RX, TX pinovi, primjerice 2 i 3, možeš koristiti bilo koje druge
void setup() {
Serial.begin(9600);
Serial.println(“Početak komunikacije s ESP8266…”);
espSerial.println(“AT”); // testiraj komunikaciju
void loop() {
Otvori Serial Monitor (9600 baud), postavi “Both NL & CR” i testiraj s AT. Ako vrati OK, veza s ESP8266 je uspostavljena.
:globe_with_meridians: Spajanje na WiFi mrežu Nakon AT, upiši sljedeće naredbe:
AT+CWMODE=1
AT+CWJAP=“ime_wifi_mreže”,“lozinka”
Ako sve prođe dobro, vraća WIFI CONNECTED.
:outbox_tray: Slanje HTTP zahtjeva (primjer GET):
AT+CIPSTART=“TCP”,“example.com”,80
AT+CIPSEND=47
GET / HTTP/1.1
Host: example.com
:white_check_mark: Savjeti: Ako ESP ne odgovara, provjeri napajanje i logičke nivoe. Preporučuje se 1000 µF kondenzator blizu napajanja ESP-a kako bi ‘izgladio’ nesavršenosti u napajanju. Ovo je neki osnovni tutorial, molim te javi ako ESP8266 odgovaran a “AT” komandu. Ako ne odgovara probaj 115200 baud rate. Ako još uvijek ne odgovara, moguće je da se na ESP8266 tek taj AT-commands sketch mora flashati, s čime mogu pomoći ako to utvrdimo.
Nadam se da će raditi, sretno!
I’ve stepped down the voltage to 3.3V for the ESP8266 using a step-down converter. I’ll test tomorrow and report back.
Uredu, ja sam preko step down- spustio napon na 3.3 V za esp8266. Probam sutra pa se javim.
Attachment omitted in migration: 1000024876.jpg
Attachment omitted in migration: 1000024875.jpg
Attachment omitted in migration: 1000024877.jpg
A step-down converter can work for power, but the serial communication lines (RX and TX pins) must also go through a logic level converter – just to clarify so you don’t connect the TX pin to the ESP8266 RX and damage it, since it can only tolerate 3.3V maximum.
Pozdrav, može preko step down da, ali logic level (serijska komunikacija, RX i TX pinovi) također moraju biti preko nekog logic level konvertera - samo napominjem kako ne bi spojili TX pin na esp8662-ov RX i onda bi ga oštetili jer on prima 3V3 max.
