Ethernet Shield MAC address, ICSP connector placement, and direct PC connection
I have a few questions about the Ethernet Shield:
  1. I can’t find the MAC address on this shield. How should I determine it?
  2. For future shipments of the Ethernet Shield, would it be possible to have the ICSP connector soldered on the top side of the board, as a male connector (on the bottom side), or not soldered at all? The current implementation is quite impractical.
  3. Do you have any documentation on connecting the Ethernet module directly to a PC using a crossover cable, for testing without a router?
Thank you for your help.
Molim vas za još nekoliko informacija u vezi Ethernet shielda:
  1. Nisam uspio naći MAC address na ovom shieldu, pa bi vas molio za preporuku kako to odrediti
  2. Da li je za buduće isporuke Ethernet shielda moguće organizirati tako da je ICSP konektor zalemljen s gornje strane pločice ili da je muški (s donje strane pločice) ili da ga uopće ne zalemite (trenutno je to napravljeno poprilično nepraktično)
  3. Da li možda imate kakve upute o spajanju Ethernet modula direktno na PC (preko „crossover“ kabela) – za test bi probao izbjeći ruter
Hvala vam lijepo na pomoći. LP,
Originally submitted via the contact form on soldered.com on 27 December 2017. Migrated to the forum for community visibility.
  1. You can set the MAC address yourself if it’s not written on the shield.
  2. Since this shield is not from our production, we unfortunately cannot modify the connector. It’s currently designed to connect with a 2x3 male connector, which is standard on full-sized Arduino shields. If it helps, we can (more or less neatly) desolder the connector so you can install whatever suits you best.
  3. I haven’t used it myself, but I believe it should work out of the box. Here’s a brief explanation of how to configure it: https://arduino.stackexchange.com/questions/22700/connecting-ethernet-shield-to-computer
Of course, with a crossover cable as you mentioned. A router would normally handle this automatically. On the Arduino side, you can use the Ethernet library like with any other Ethernet code. Unfortunately I’d have to try it myself to be 100% certain.
  1. MAC adresu sami možete zadati ako je nema napisane na shieldu.
  2. Budući da ovaj shield nije iz naše proizvodnje.. nažalost ne možemo mijenjati konektor. Sada je napravljeno da se spaja s 2x3 muškim konektorom kakav obično bude na full-sized Arduino shieldovima.
    Ako Vam nešto znači, možemo (više ili manje uredno) odlemiti konektor pa možete Vi staviti šta god Vam bude odgovaralo…
  3. Nisam nikada koristio, ali mislim da bi to trebalo raditi “out of box”. Ovdje je ukratko objašnjeno kako konfigurirati: https://arduino.stackexchange.com/questions/22700/connecting-ethernet-shield-to-computer
    naravno s crossover kabelom, kako i sami kažete. Ruter to inače automatski odradi..
    što se tiče Arduino strane, mislim da tu dalje ide i kao bilokoji drugi ethernet kod - možete koristiti ethernet library. Nažalost morao bih probati da budem 100% siguran
