I purchased a Croduino Basic a few years ago. Since I lost the instructions, I don’t know how to get started. I have an LED, resistor, and pushbutton connected on a breadboard to the Croduino, and the LED lights while the button is pressed. I’m looking for advice or instructions on how to proceed.
Kupio sam kod vas croduino
2 basic, prije par godina.Budući da sam izgubio uputstva ne znam kako započeti.Napominjem da je na experimentalnoj pločici spojena jedna LED-ica,otpornik i tipkalo i sve to spojeno s croduinom te LED-ica svjetli dok je tipkalo pritisnuto, molim savjet ili uputstvo , kako dalje.Sve troškove plaćam.
LP TT BELIŠĆE , VSH GUTMANNA14C
Originally submitted via email support on 24 May 2022. Migrated to the forum for community visibility.
To start, I recommend checking out the video tutorials at https://www.youtube.com/c/eradionicacomhr/videos - they’re a good introduction to programming and getting familiar with microcontrollers.
For your circuit, you’ll want to use simple code that reads the button state and turns on the LED when pressed. To begin programming, here’s a guide with driver installation instructions and everything you need to upload code: https://e-radionica.com/hr/blog/2018/11/07/programiranje-croduino-basic3-iz-arduino-ide/
If you run into a specific problem, let us know and we can help. If you want to learn programming more broadly, I suggest searching online for some beginner projects and simple things to try, then ask if anything isn’t clear.
Za početak, ako planirate raditi s Croduinom predložio bih Vam da pogledate naše video tutorijal na linku https://www.youtube.com/c/eradionicacomhr/videos. Oni su dobar uvod u programiranje i upoznavanje mikrokontrolera.
Za vaš spoj bih rekao da koristi jednostavan kod koji čita stanje tipkala i kada se pritisne upali LED diodu. Za početak programiranja šaljem Vam link https://e-radionica.com/hr/blog/2018/11/07/programiranje-croduino-basic3-iz-arduino-ide/ s uputama za instalaciju drivera i svega potrebnoga za upload koda. Ako Vam treba neko rješenje za određeni problem javite nam se te Vam pomognemo. Ako pak želite samo naučiti programirati Croduino predlažem da malo pretražite po internetu neke projekte i jednostavnije početničke stvari te onda pitate što nije jasno.
Trenutno nemamo više od ovi video lekcija te Vam možemo samo pomoći putem maila, ali pripremamo korisne tutorijale za jednostavne projekte koji će uskoro biti dostupni na našim stranicama.
