The product page for the GNSS GPS L86-M33 breakout with easyC mentions that the recommended antenna is the Active GPS Antenna with SMA connector. The problem is that the connectors appear to be incompatible. Is this an error in the product description, or am I misunderstanding how they should connect?
Imam jedno jako jednostavno pitanje; na stranici GPS & Location | Location Data for Embedded – Soldered Electronics je spomenuto da je preporučena antena GPS & Location | Location Data for Embedded – Soldered Electronics .
Problem je što su konektori incompatible, je li ovo pogreška pisanja ili ja ne shvaćam kako treba.
(koristim engleski i hrvatski u svakodnevnom govoru – nadam se da razumijete upit.)
Hvala vam!
Teo
Originally submitted via email support on 16 April 2024. Migrated to the forum for community visibility.
There was an error in the product description. The module comes with a built-in antenna that is sufficient for receiving signals. The module has the option to connect an external antenna, which can be connected to the IPX connector on the board. An external antenna is not required for normal operation, but can be added if the signal is weak and you want to position the antenna separately from the module (for example, the module inside a building and the antenna extended outside via a cable).
Zahvaljujemo što sete prijavili jer je došlo do pogreške prilikom pisanja opisa proizvoda.
Proizvod dolazi s ugrađenom antenom koja je dovoljna za prijem signala. Sam modul ima opciju spajanja vanjske antene te se ona može spojiti na IPX konektor koji smo postavili na pločicu. Vanjska antena nije potrebna za normalan rad, ali se može dodati ako je signal slab te se antena želi postaviti na drugo mjesto od modula (npr. modul unutar zgrade, a antena se kablom izvuče van zgrade).
Ispričavamo se zbog nastalih nejasnoća
