GPS Module coordinate readout and precision specifications
I’ve installed the drivers for the GPS module, but I need an application to read coordinates. Can you help me find software for using the GPS module? Can it be used with cadastral data, and can I read a specific point like a boundary marker, and what precision can I expect?
Hvala na upitu, drajvere za GPS modul sam instalirao no treba mi neka aplikacija preko koje mogu očitavati koordinate pa bih Vas molio za pomoć oko programa za korištenje GPS modula. Da li se to može koristiti sa arkodom ili katastrom i da li ja mogu očitati neku točku recimo stup međe i s kojom preciznošću?
L.p. [name removed]
Originally submitted via the contact form on soldered.com on 16 August 2023. Migrated to the forum for community visibility.
For this GPS module, you need to use the official U-Center software. You can download it from u-center | u-blox under “Product Variants / Ucenter”.
Once you start the program, you need to select the correct USB port where the GPS module is connected, and then you’ll be able to read the data. For detailed instructions on using the program, here’s a YouTube tutorial: https://www.youtube.com/watch?v=I0yBO7SIpnY&t=1s
The precision of this GPS module is ~2.5 meters.
malo sam istraživao i naišao na to da se za taj GPS modul treba koristiti njihov službeni program U-Center. Možeš ga preuzeti na sljedećem linku: u-center | u-blox
Nalazi se pod “Product Variants / Ucenter”.
Nakon pokretanja tog programa, potrebno je izabrati dobar USB port na kojem je spojen GPS modul i onda će se moći pročitati podatci. Za detaljno korištenje tog programa pronašao sam ovaj YouTube tutorial: https://www.youtube.com/watch?v=I0yBO7SIpnY&t=1s
Preciznost tog GPS modula je ~2.5 metara.
