I’m interested in article 101180 (GSM/GPRS ANTENA 5DBI, 1.5M KABEL, SMA-M). Can you provide the specifications for this antenna? I want to use it as an external antenna for a TP-LINK Archer MR200 device with a built-in LTE modem.
Zanima me artikl pod šifrom 101180 (GSM/GPRS ANTENA 5DBI, 1.5M KABEL, SMA-M), tj. možete li mi poslati karakteristike ove antene koju bi koristio kao vanjsku antenu za uređaj TP-LINK Archer MR200 sa ugrađenim LTE modemom. Hvala.
Originally submitted via email support on 11 November 2016. Migrated to the forum for community visibility.
I’ve updated the product description with a list of supported frequencies and the antenna impedance: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics Unfortunately I don’t have more details available. I’ve sent a request for the datasheet and will let you know if it becomes available.
update-ao sam opis proizvoda s popisom podržanih frekvencija i impendancijom antene: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Nažalost nemam više detalja. Poslao sam upit za datasheetom, svakako ću javiti ako je dobavljiv!
