HC-12 RF Module headers compatibility and soldering
Will these headers work with the HC-12 RF module? Can you confirm they’re suitable for soldering?
I da li mi mozete reci hoceju li ovi headeri biti dobri za ovaj skuplji RF modul?
Originally submitted via email support on 4 July 2018. Migrated to the forum for community visibility.
The pin spacing is identical on both the headers and the HC-12, so there should be no problem soldering the male headers to the board and then making the connection with the female (stackable) header.
Vezano za Vaš upit u vezi headera i HC-12, razmak između pinova je identičan na oba artikla tako da ne bi trebalo biti problema zalemiti muške headere na pločicu te onda na taj način ostvariti konekciju sa ženskim (složivim headerom).
Attachment omitted in migration: Ponuda KUPCI-GRAĐANI_168_2018.pdf
