Humidity Sensor received with only 2 cables instead of 4
I received 2 cables for connecting the sensor instead of 4 cables. How can I buy new cables and what part numbers do they have?
Ja sam od vas dobio 2 kabela za povezivanje senzora,umjesto 4 kabela.Kako cu kupiti nove kabele,koju oznaku nose?
Sent from [name removed] Mail on Android
Originally submitted via email support on 25 January 2018. Migrated to the forum for community visibility.
Connection should be straightforward: connect power and communication, then read that pin on the micro:bit as HIGH or LOW (presence or absence of current). Use the potentiometer on the board to adjust the sensitivity of that output.
Connection diagram:
micro:bit → sensor
3V → +5V
gnd → gnd
0 (or 1 or 2) → DO
You received two cables for connecting the sensor and the small breakout board mentioned above. It does not come with cables for connecting to other boards. For Arduino you need: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
For micro:bit: 10x kabela s aligator kopčama – Soldered Electronics
spajanje bi trebalo biti jednostavno; spojite napajanje te komunikaciju, a na micro:bitu očitavajte taj pin kao HIGH ili LOW(ima/nema struje). Pomoću potenciometra na pločici podesite osjetljivost tog izlaza. micro:bit senzor 3V +5V gnd gnd 0(ili 1 ili 2) DO Stigla su Vam dva kabela, za povezivanje senzora i male breakout pločice o kojoj govorimo iznad. Ne dolazi s kablovima za povezivanje s drugim pločicama. Za Arduino Vam trebaju kablovi: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
