Do you have a technical drawing for this module? I need to know the hole diameter so I can get the right spacers and screws.
Bok,imate tehnički crtež ovog modula? Zanima me promjer rupa da znam koje odstojnike i vijke nabaviti Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Originally submitted via Facebook on 12 May 2020. Migrated to the forum for community visibility.
We don’t have a drawing available, but we can tell you the details: dimensions are 25 x 22mm, the holes have a diameter of 3.2mm, and their centres are 2.5mm from the edges.
Bok [name removed]! Nažalost nemamo crtež, ali ti možemo sve reći: dimenzije su 25 x 22mm, rupe promjera 3.2mm i njihovo središte udaljeno je 2.5mm od rubova.
Ako smo što zaboravili, javi!
I forgot to ask—what thread size is on this load cell?
Joj,zaboravio sam još pitati koji su navoji na ovom load cellu?
https://e-radionica.com/hr/loadcell-senzor-20kg.html
The hole is for an M5 screw.
Naravno, rupa je za vijak M5
