HX711 breakout compatibility with 120kg load cell
Do you stock an ADC with op-amp for use with the 120kg load cell module? What would you recommend for an ADC and op-amp?
ili što predlažete da se koristi za adc i op?
Originally submitted via email support on 14 December 2017. Migrated to the forum for community visibility.
We have our HX711 breakout (PGA+ADC, designed specifically for load cells). It’s not currently on the web shop yet, but it has been tested and works correctly.
imamo naš HX711(PGA+ADC, baš za loadcellove) breakout. Trenutno nije na web shopu, nismo ga još stigli postaviti, ali je testiran i ispravan.
Have you tested the HX711 with the 120kg load cell module? I’ve seen HX711 modules online that only work with 1-20kg load cells.
Dali ste taj vaš HX711 testirali i ispitali s ovim modulom od 120kg ? ( jer na internetu ima hx711 s modulima od 1-20 kg)
Yes, it works excellently with the 120kg load cell. Actually, it will work with any load cell.
da, radi odlično s loadcell-om od 120kg(zapravo, radit će s bilokojim loadcellom)
