Dear community,
I cannot get the hx711 breakout sensor to work with micropython.
I am trying to get the LOAD-CELL AMPLIFIER HX711 WITH QWIIC to work. I connected the sensor via QWIIC to the SDA/SCL pins and 3.3V and Ground. I have verified that i2c works in this setup with other i2c sensors. I put the [hx711.py] (Soldered-MicroPython-Modules/Sensors/HX711/HX711/hx711.py at main · SolderedElectronics/Soldered-MicroPython-Modules · GitHub) on the board and used one of the examples, hx711-basic.py (as well as tried other things). I only ever got a reading of 0. I checked and this zero is actually due to a [Errno 116] ETIMEDOUT.
When I compared it with the Arduino library, there is not explicit .begin() call.
Maybe my problem is in front of the computer :), but it would be nice to know if you have any ideas what I could try.
I tried it with two different boards, two different load cells, two methods of connecting them (soldered / pin and sockets).
