I found another library on your site: Soldered-16x2-LCD-Arduino-Library-main.zip
Now I see there’s another library too.
But now I see I have a new problem. I solve one, another appears.
Until now I used GitHub - forntoh/LcdMenu: Display navigable menu items on your LCD display 📟 with Arduino · GitHub to create menus, and I tested that on a different I2C LCD adapter that has a different chip from yours, and everything worked fine.
Now that I’ve switched to your I2C LCD adapter, the program won’t compile.
Users/tlevakov/Documents/Arduino/libraries/LcdMenu/src/LcdMenu.h:29:31:
fatal error: LiquidCrystal_I2C.h: No such file or directory
That LcdMenu appears to be tied exclusively to that library.
Do you have another library for menus or some other suggestion?
Hvala na odgovoru.
Na Vasoj stranici sam nasao ovaj library
Sad vidim da ima jos jedan library, hvala
No, sad vidim da imam novi problem, jedan rijesim, drugi se pojavi.
Do sada sam koristio GitHub - forntoh/LcdMenu: Display navigable menu items on your LCD display 📟 with Arduino · GitHub za izradu
menija, i to sam probavao na jednom “I2C LCD adapteru” koji ima drukciji
chip od ovog Vaseg, i sve je radilo OK.
Sad kako sam “presao” na I2C LCD adapter od Vas, program se ne zeli
kompajlirati.
Taj LcdMenu je izgleda vezan iskljucivo uz taj library.
Da li imate nekakav drugi library za menije ili nekakkav drugi savjet.
Hvala !
