I found a problem with the I2C LCD adapter that seems to be causing the display to run slowly and with dim backlight. I tested another adapter I have and the LCD works fine. I suspect there’s a design flaw in your board.
On pins A and C for the backlight, the voltage should be 5V but I’m measuring 3V3. Your official pinout diagram also specifies 5V for these pins. The LCD datasheet also confirms it’s designed for 5V with an RF resistor of 91kohm.
Is there a way to modify the LCD breakout so I can get 5V on pins A and C?
Cini mi se da sam nasao problem zasto je Vas LCD display “spor” i
“slabo” backlight svijetli…
Problem je u Vasem I2C LCD adapteru…Probao sam drugi koji imam i
LCD je OK.
Pa si pregledajte da nije nekakav “design flaw”…
Naime, na pinovima “A” i “C” za backlight bi trebalo biti 5V a ja imam
3V3.
Cak i na Vasem sluzbenom pinoutu od breakouta pise da je 5V, slika u
prilogu.
A i u datasheetu od LCD displeja da je predvidjen za 5V i da ima “RF”
otpornik 91kohm, sto je tocno.
Jel ima kakav nacin da ja to nesto prespojim na LCD breakoutu da dobijem
5V na A i C pinovima?
Attachment omitted in migration: I2C-LCD-driver.png
Attachment omitted in migration: Soldered_20x4_lcd_datasheet.pdf
Attachment omitted in migration: IMG_20240312_110556.jpg
Attachment omitted in migration: IMG_20240312_110536.jpg
Attachment omitted in migration: IMG_20240312_110545.jpg
Originally submitted via email support on 12 March 2024. Migrated to the forum for community visibility.
